mirsanmimradlda
The next thing to try is prying the ears of seat lug apart slightly with a screwdriver. [Only with a steel frame, though. This can permanently damage an aluminum or carbon-fiber frame. -- John Allen] Sometimes it is easiest to stick a flat-bladed screwdriver between the ears and twist gently. Other times you may have better luck by inserting a large Phillips head screwdriver or Allen wrench into the bolt hole on one ear at a time and bending the two sides individually.
Na wenn's der Meister sagt
