Garmin etrex vista hcx outdoor gps
AW: Garmin etrex vista hcx outdoor gps
Change History
Changes made from version 3.10 to 3.20:
◦Fix shutdown issue when press menu key at first power on with 100% backlight setting.
◦Fix minutes to hours roll over issue.
Changes made from version 3.00 to 3.10:
◦Fix potential lock up when SD card installed.
◦Fix the contour data intermittently drawing over interstates of Topo Map.
◦Improve the blue shading color when using the setting 'Marine colors' in Daytime display mode.
◦Correct the brightness can't move over 50% in eTrex Vista HCx.
◦Correct upside down direction of vertical speed.
◦Fix incorrect highlight index at unit field in 'Area Calculation' page after select reset in menu.
Changes made from version 2.80 to 3.00:
◦Correct time scale of altimeter chart.
◦Add support for maps greater than 2 GB.
◦Modify track log function for steady barometer output at power on.
Changes made from version 2.70 to 2.80:
◦Fix 'Highway Page' shutdown issue with menu key operation.
◦Correct power-on failure issue.
Changes made from version 2.60 to 2.70:
◦Improve distance calculation in odometer.
◦Fix system freeze issue.
◦Fix shutdown issue when browse detail map.
◦Correct user grid.
◦Disable route calculation icon when GPS is off.
Changes made from version 2.50 to 2.60:
◦Correct German translation of 'delete all waypoints'.
◦Fix data card unlock failure when 2 cards of the same map set are used in one device.
◦Improve sun times for polar regions.
◦Fix issue where ETA in non motor vehicle modes can be unreasonably short.
◦Increase precision of distance measurement to the cursor on the map page.
◦Allow backlight adjustment on the track back point selection page.
◦Fix shutdown when editing Estonian Grid coordinates.
◦Correct daylight saving time for New Zealand.
◦Improve selection of the names of cross roads with NT maps.
◦Correct potential shutdown when viewing a vertical profile.
◦Correct European word translation of 'Find' and 'Mark'.
◦Support multiple languages in American version.
◦Fix screen fading issue in cold temperature.
◦Correct total ascent calculation.
◦Correct direction symbol of vertical speed.
◦Fix reboot issue of GPS firmware update.
◦Correct battery issue of lithium battery.
Changes made from version 2.40 to 2.50:
◦Removed the turn backlight on action when unit is initially powered on.
Changes made from version 2.30 to 2.40:
◦Fix compass hint message issue when compass turn off.
◦Changed odometer calculation to more closely match track log distance.
◦Change number of lines of text in the address field on map feature review page from 4 to 6.
◦Limit number of custom POI bitmaps to 64 to ensure enough memory resources.
◦Added better compatibility with Mac computers in USB mass storage mode
◦Improved pedestrian route calculation for shortest distance method.
◦Changed datum used in the SWEREF 99TM grid from GEO_NAD83 to GEO_NONE_GRS80.
◦Changed datum used in the Estonian grid from GEO_NAD83 to GEO_NONE_GRS80.
◦Fix potential shutdown when using TOPO West 1999.
◦Fix potential shutdown on track setup for data card when track log files have long file names.
◦Corrected French translation for 'Log track points'.
◦Improve track log recording for sensor products to continue recording sensor data even when GPS doesn't have a fix.
◦Fix potential shutdown when propagating in a cul-de-sac across a map boundary.
◦Add A905/D900 unlock code communication protocol.
◦Make route recalculation on MPC maps behave like City Navigator maps.
◦Fix second power on issue.
◦Fix WebUpdater issue of GPS firmware.
Changes made from version 2.20 to 2.30:
◦Fixed Swiss grid issue.
◦Fixed postcode issue with CNE v.9 NT.
◦Added hint message when the E-compass of the unit has never been calibrated successfully by user.
◦Change 'Lithium Ion' text to 'Lithium'
Installation Instructions
1.It is recommended that you disable screen savers or other programs running on your PC while you go through the update process. Disruptions to the update process may render your GPS inoperable. If the transfer is interrupted, turn off the GPS and then turn it back on. Reboot your PC, go to step #9 and attempt the download again. GARMIN is not responsible for failed downloads of operating software to the GPS and factory resetting the GPS unit will fall under our Flat Rate Repair Policy.
2.Click on 'Download' and choose to save the file to your computer.
3.Choose a location where you can easily locate the file by saving it to a location such as the 'My Documents' folder or to 'C:\'.
4.Once the download is complete, go to the location where you saved the file.
5.Locate the downloaded file and double-click on it. This will launch the Win-Zip Self Extractor. This program compresses the data to allow for a faster download of the needed files.
6.A program window will appear asking you where to 'Un-zip' the files. This is by default C:\Garmin. You can change this location if you like. Be sure to note where the un-zipped files are going to allow you to find them!
7.Click on the button labeled 'Un-zip'.
8.Once the un-zip process is complete, click on the 'Close' button to exit the Win-Zip Self Extractor.
9.Connect your GPS to your computer using a GARMIN PC Interface cable to an open USB port. Turn the GPS on.
10.If your computer asks for a driver, please see the software and installation instructions that came with your device, or download and install the USB driver from Garmin's website at www.garmin.com.
11.Open the C:\Garmin folder (or other folder where you un-zipped the files), locate the file named 'Updater' and double click on it.
12.You should see the name of your GPS device next to the 'USB Device' option on the Updater program window. Select the 'USB Device' option, then click on 'OK' on the Updater program window to start the data transfer.
Re: Garmin etrex vista hcx outdoor gps
