Mir vielleicht auch?Könntest du mir dein modifiziertes Script vielleicht zukommen lassen?
#!/usr/bin/env python3
import os
import re
from pathlib import Path
from datetime import datetime
from getpass import getpass
import logging
import garth
from garth.exc import GarthException, GarthHTTPError
from fit_tool.fit_file import FitFile
from fit_tool.fit_file_builder import FitFileBuilder
from fit_tool.profile.messages.record_message import RecordMessage, RecordTemperatureField
from fit_tool.profile.messages.session_message import SessionMessage
from fit_tool.profile.messages.lap_message import LapMessage
from fit_tool.profile.messages.file_id_message import FileIdMessage
# === Logging ===
SCRIPT_DIR = Path(__file__).resolve().parent
log_file_path = SCRIPT_DIR / "myWhoosh2Garmin.log"
logger = logging.getLogger(__name__)
logger.setLevel(logging.DEBUG)
file_handler = logging.FileHandler(log_file_path)
formatter = logging.Formatter('%(asctime)s - %(levelname)s - %(message)s')
file_handler.setFormatter(formatter)
logger.addHandler(file_handler)
# === Pfade ===
MYWHOOSH_PATH = Path("/home/Barst/Downloads")
BACKUP_PATH = MYWHOOSH_PATH / "backup"
BACKUP_PATH.mkdir(exist_ok=True)
# === Garmin Auth ===
TOKENS_PATH = SCRIPT_DIR / '.garth'
def authenticate_to_garmin():
try:
if TOKENS_PATH.exists():
garth.resume(TOKENS_PATH)
else:
username = input("Garmin Benutzername: ")
password = getpass("Garmin Passwort: ")
garth.login(username, password)
garth.save(TOKENS_PATH)
logger.info(f"Authenticated as: {garth.client.username}")
except GarthException as e:
logger.error(f"Garmin Auth Fehler: {e}")
exit(1)
# === Hilfsfunktionen ===
def calculate_avg(values):
return round(sum(values)/len(values),1) if values else 0
def append_value(values, message, field_name):
val = getattr(message, field_name, None)
if val is not None:
values.append(val)
def reset_values():
return [], [], []
def get_most_recent_fit_file(folder: Path) -> Path:
fit_files = list(folder.glob("*.fit"))
if not fit_files:
return None
return max(fit_files, key=os.path.getctime)
def generate_new_filename(fit_file: Path) -> Path:
timestamp = datetime.now().strftime("%Y%m%d_%H%M%S")
return BACKUP_PATH / f"{fit_file.stem}_{timestamp}.fit"
# === Hauptlogik ===
def cleanup_fit_file(fit_file_path: Path, new_file_path: Path):
builder = FitFileBuilder()
fit_file = FitFile.from_file(str(fit_file_path))
cadence_values, power_values, hr_values = reset_values()
for record in fit_file.records:
msg = record.message
if isinstance(msg, FileIdMessage):
# Override manufacturer/product but keep other fields
msg.manufacturer = 1
msg.product = 1836
if isinstance(msg, LapMessage):
continue
if isinstance(msg, RecordMessage):
msg.remove_field(RecordTemperatureField.ID)
append_value(cadence_values, msg, "cadence")
append_value(power_values, msg, "power")
append_value(hr_values, msg, "heart_rate")
if isinstance(msg, SessionMessage):
if not msg.avg_cadence:
msg.avg_cadence = calculate_avg(cadence_values)
if not msg.avg_power:
msg.avg_power = calculate_avg(power_values)
if not msg.avg_heart_rate:
msg.avg_heart_rate = calculate_avg(hr_values)
builder.add(msg)
# Datei bauen und speichern
builder.build().to_file(str(new_file_path))
logger.info(f"Bereinigte Datei gespeichert: {new_file_path}")
# === Main ===
def main():
latest_fit = get_most_recent_fit_file(MYWHOOSH_PATH)
if not latest_fit:
logger.error(f"Keine FIT-Dateien in {MYWHOOSH_PATH} gefunden.")
exit(1)
logger.info(f"Neueste Datei: {latest_fit}")
new_file = generate_new_filename(latest_fit)
try:
cleanup_fit_file(latest_fit, new_file)
except Exception as e:
logger.error(f"Fehler beim Bereinigen: {e}")
exit(1)
# Upload zu Garmin
try:
with open(new_file, "rb") as f:
garth.client.upload(f)
logger.info(f"Erfolgreich hochgeladen: {new_file}")
except GarthHTTPError:
logger.info("Aktivität möglicherweise schon bei Garmin Connect vorhanden.")
if __name__ == "__main__":
main()
Danke für deine Info's.Ich klicke auf mein Profil und dann wird der ZwiftHub sofort angezeigt bei der PowerSource.
Bei HR wird erstmal für 3s nichts angezeigt bevor dann der Tickr angezeigt wird.
Den ZwiftHub hab ich bei der Herzfrequenz noch nie gesehen.
Ich nutze mywoosh am iPad falls das relevant ist.
Zeigt er dir auch alle Daten der Trainingsbelastung an? Trainingszustand, Erholung, akute. Belastung etc.Funktioniert jetzt super. Die neuste Fit-Datei im festgelegten Ordner wird automatisch zu Garmin hochgeladen und zeigt auch den Trainingeffekt.
Man könnte sich die FIT-Datei direkt von Strava holen oder?Den automatischen Download kann man bestimmt auch noch irgendwie hinbekommen. Allerdings nervt mich im Moment mehr, dass die Fit-Dateien neuerdings erst nach Stunden zum Download bereit stehen. Und das, obwohl sie schon lange auf Strava zu sehen sind.
Das habe ich dann auch gemacht. Mit dieser Fit hatte aber das Script nicht funktioniert. Mit Fitfiletools kann man online den Hersteller der Datei ändern. Dann berechnet Garmin auch die Trainingsbelastung. Dieser Weg ist aber aufwändiger.Man könnte sich die FIT-Datei direkt von Strava holen oder?
# --- Schritt 1: Pakete installieren ---
!pip install fit-tool
# --- Schritt 2: Imports ---
# --- Schritt 3: Upload-Funktion ---
from google.colab import files
def upload_fit_file():
print("Bitte FIT-Datei hochladen...")
uploaded = files.upload()
file_name = list(uploaded.keys())[0]
return Path(file_name)
# --- Schritt 4: Bereinigungsfunktion ---
return round(sum(values)/len(values), 1) if values else 0
if val is not None:
values.append(val)
def reset_values():
return [], [], []
def cleanup_fit_file(fit_in: Path, fit_out: Path):
fit_file = FitFile.from_file(str(fit_in))
msg.product = 1836
continue
builder.add(msg)
builder.build().to_file(str(fit_out))
print(f"Bereinigte Datei gespeichert: {fit_out}")
# --- Schritt 5: Workflow ---
fit_file = upload_fit_file()
output_file = Path(f"{fit_file.stem}cleaned{datetime.now().strftime('%Y%m%d_%H%M%S')}.fit")
cleanup_fit_file(fit_file, output_file)
# --- Schritt 6: Download der bereinigten Datei ---
files.download(str(output_file))
Gestern ging's bei mir wieder schnell (30 Minuten).Mein gestriges Workout ist nicht online unter den Activities zu sehen. Habe es öfters, dass das dauert, aber so lange noch nie. Ging/geht es noch jemandem so?
Bei mir war sie dann auch nach knapp einem Tag online. In der mywhoosh-App im Kalender war sie aber auch sofort zu sehen, denke das wäre ein guter Indikator, falls wirklich was verloren gegangen wäre.Gestern ging's bei mir wieder schnell (30 Minuten).
Vor ein paar Tagen hat's bei meiner Frau einen Tag gedauert und bei einem Bekannten sogar zwei Tage.
Auch wenn's mal länger dauert, es ging bei mir noch keine Aktivität verloren.![]()
