A cheerful "Hello” and a "Welcome to the forums”.
Nice polishing work done, but I also think it’s time to harden your cones now, in order to give them a more durable surface. By polishing, you almost certainly removed the hard surface; thus they would give up prematurely, as already said by the croc.
My advise is to heat them up to a nice reddish glow and then just sink them in a glass of rapeseed oil. This is what the knife enthusiast and collectors do when they want to add a hard wearing surface to their blades without giving up on flexibility like it would happen by using water. The vast temperature shock would result in "glass hardness” and the knife would crack under the first use. This could also happen to your cone. By hardening it in rapeseed oil, you would archive a hard surface without exposing your part a temperature drop too immense; it would not become brittle and maybe slightly change its shape (which is always a risk when it comes to harden metal). This also has to do with how fast or slow the medium consumes the heat; oil will cool the metal down slower causing less stress. The result should be a hardened surface.
Btw, I’m from Shepshed, raised there my first six years. I am in collecting british and scottish machines (mostly barrows, only a few two wheeled machines here) and I am in the process of moving a couple of them back to Britain as I also own a property in England. I’ve been commuting between Germany and England the last years. I am also in collecing british astronomical telescopes. I often wish I had a toolmaker’s knowledge; I know one here in Germany and he explained me how to tap and cut threads, which is highly useful for one who collects historic telescopes. That chap is an elderly person who was trained in England when he was a prisoner of war. He also got married there, both moved to Germany later. He still runs his shop (!) and is a expert in threads.
Enjoy your stay!
Peter
