@Ebe66
Thanks for your answer and your great work in this project.
I did some further tests and discovered the following (Cache was always cleared):
1st:
I deleted all routing tiles on the roam V2 and then uploaded the GPX Track into the roam via Elemnt App. The result is that the routing list is empty. So in this case, the roam needs the routing tiles to generate the TBT directions.
2nd:
now i downloaded the original maps and routing tiles for bavaria via the elemnt app to the roam. I took the same GPX Track from the 1st try and imported it. Now the TBT directions are genereted.
3rd:
again, I deleted all routing tiles and map tiles on the roam and downloaded the Germany Map and Routing Tiles from the HiDrive to the roam, took the GPX Track from the 1st try and imported it again. TBT directions are genereted again, BUT they are slightly different to the directions in 2nd try and they are not a
100% correct and less than in 2nd try.
Table of the directions:
| 2nd try | 3rd try |
| Fortsetzen | Fortsetzen |
| SchXXXstr. | SchXXXstr. |
| DoXXXße | FuXXXe |
| DXXX8 | Rechts abbiegen |
| 1. Ausfahrt Kreisverkehr | |
| WeXXXr. | |
| BäuXXX Str. | BäuXXX Str. |
| AlXXXg | AlXXXg |
| Ankunft | Ankunft |
4rd:
again, I deleted all routing tiles and map tiles on the roam and then downloaded the original maps and routing tiles for bavaria via the elemnt app to the roam. Deleted the original map files and uploaded the map files from the HiDrive to the
wahoo, took the GPX Track from the 1st try and imported it again. TBT directions are genereted again and look like in the 2nd try.
The TBT directions from the 2nd and 4rd try are for me the correct ones. When I drive the route with this directions, everything is fine. Do I drive the route with the directions from the 3rd try, this feels bad.
So for me, it seems that the roam has some problems with the routing tiles from the HiDrive.
BR
Thomas
