FTP - Aktuelle Zahlen und Ziele
Danke euch erstmal für die Werte :) Denke übertreiben müssen wir das Spielchen nicht :D
Re: FTP - Aktuelle Zahlen und Ziele
mehr davon. Genau so wars gemeint. Schönes Wochenende. Wers messen will sollte mal seine Körpergröße und die Überhöhung mit einbeziehen. macht natürlich was aus ob 1,60 oder 1,90cm.
Aber aero optimierung bringt schon merklich was für den Spaß..
weil man jetzt von den watts zu aero und zu den geschwindigkeiten gekommen ist,
bei denen welche watts getreten werden sollten oder wie auch immer ... :idee:
Hi guys,
this is a great article for everybody who tries to find his/her perfect position on the bicycle ...
How Aero is too Aero?
Dropping your torso may help you slice through the air,
but at some point you pay the price in power.
Here’s how to find your aero sweet spot.
BY SELENE YEAGER
http://www.bicycling.com/training-n...aero?cid=NL_BIK_2034580_BIK_02262015_too_aero
Aero is everything…until it’s not.
On a flat road, aerodynamic drag is your biggest obstacle. You use about 80 percent of your power output to overcome wind resistance when you’re hammering down the road. Using aerobars and dropping your torso toward your top tube shrinks your frontal surface area, making it easier to slip through the wind and go faster. But as a new study points out, there’s a point of diminishing returns, because it’s harder to take full deep breaths and to push the pedals to produce maximum power when you’re all hunched over.
To show how dramatic an impact extreme aero positions can have on power output, a team of British researchers had 19 trained cyclists perform a series of power tests, starting at a 24-degree torso angle and dropping incrementally to zero (or as close as possible; not everyone could get that low). Every performance parameter tested, including efficiency, heart rate, cadence, V02 max, and peak power output worsened as the torso angle dropped. Power output fell 14 percent—51 watts—from the highest position to the lowest. Of course, the cyclists’ frontal area was also reduced (by up to 14 percent) as they got lower. So the riders would be more aero in real-world conditions. However, the researchers concluded the lowest position hindered performance so much that it should be avoided even by trained competitive cyclists. For the other positions, it’s a trade-off between how many watts you lose to impaired performance versus how many you gain in aerodynamic advantage.
“It’s pretty easy to test for yourself with a power meter,” says power-training guru Hunter Allen of Peaks Coaching Group. “But you can also test it by simply using speed and RPE [rating of perceived exertion].” Here’s what he recommends:
Establish a baseline. Find a nice flat section of road that you can ride uninterrupted. Cover up your computer so you can’t see your numbers. Then, using your normal position, do two out-and-back runs at an RPE of 6 on a 1 to 10 scale, with 10 being as hard as you can go. Check and record your average speed.
Test yourself. Lower your torso a few degrees. Again, without looking at your numbers, repeat the course at the same RPE. Check and record your average speed. Repeat the test (without wearing yourself out) in incrementally lower positions until your average speed slows down.
Stretch and train. Keep your position right at that breaking point for three weeks, riding at least three times a week, including one long ride on the weekend. During this time, stretch your hamstrings, glutes, calves, quads, and hip flexors daily.
Retest. After three weeks, go back out and retest yourself to see if you can now ride faster in that position. If yes, lower a bit more and see if you can go faster even lower. If not, bump your position back up to where you clocked your fastest average speed.
SELENE YEAGER
guys,
i run these tests on a regular basis on my roadbike.
i get into the drops and follow the precedure described above.
these articles, i mail to you on a more or less regular basis, are from
RoadBikeMagazine, VELO, Bicycling Magazine, The Competitor,
ACE Fitness, TRAININGPEAKS etc.
R.
Gegenwind geht aber auch nur, wenns gleichmäßig ist.
Wenn es auch nur im Ansatz böig ist, ists quasi unmöglich nen Rhytmus zu finden weil man sich ja dumm und dämlich schaltet...
Also bei mir ists so, dass ich bei Rückenwind besser Leistung bringen kann.
(Wenn die Übersetzung reicht, ist am MTB bei 38-11 zum Teil schon grenzwertig da ich hohe TF's hasse)
Berg hoch mag ich bei dem test niedrigere Tf. Aber in flachen auf dem zeitfahrrad habe ich festgestellt, das ich dann doch bessere leistungen zwischen 90 und 100 Tf bringe. Dachte ich gar nicht (letztes Jahr). Mit dem wind gehts mir ähnlich wie am berg. Zumindest auf 20 min.
Gg. den Wind ist Kopfsache. Deswegen tut´s weh. Mit Rückenwind hätte die Übersetzung nicht gereicht. Wäre über 50 km/h gewesen.
windstille, rückenwind, no offense, helfen mir beim ftp-t nicht weiter.
ich bringe bessere ergebnisse bei gleichmäßigem gegenwind, egal ob leicht oder stark,
und bei leichten gleichmäßigen steigungen ...
Also bei mir ists so, dass ich bei Rückenwind bessere Leistung bringen kann.
38/11 mit rückenwind ... und keine hohen TFen ... really ... nun ja, alles ist relativ
vielleicht setz ich mich heute noch hin und rechne die entsprechenden TFen für
40 km/h, 45 km/h und 50 km/h aus - wird ja schließlich mit rückenwind gefahren
:bier:
eine TFav von 95 ist mein traum ... und wird er auch wohl immer bleiben :cool:
off topic-ker geht's schon gar nicht mehr - aber gut:
wer interesse an einer oder mehreren nagelneuen kompletten 105 11-speed gruppen für $338 (keine S&H fees) hat,
sollte sich diesen link angucken und so schnell wie möglich bei MERLIN-CYCLES in Great Britain bestellen.
http://www.merlincycles.com/shimano...pset-34-50-chainset-12-25-cassette-80109.html
ich habe am sonntag bestellt, am mittwoch kamen sie an, in originalverpackung. :daumen:
