RoKaDo
- 30 Juni 2017
Aha da steht es auch etwas weiter unten.....also laut velobase ist die Schale
Early Record bottom bracket using 3/16" balls instead of the more typical 1/4" balls. The races are pressed onto the spindle rather than machined directly on the spindle itself. Neither the cups or spindle are interchangeable with other bottom bracket components designed for 1/4" balls. Spindles are variously lettered for spindle width and BB shell. 'X 3' lettered on the spindle is for a triple <
