A...B...C...Delta - Projekt...
Wußte nicht, wo das besser aufgehoben ist:
Credits to Rob McCall (auf FB)
Enjoying getting to grips with the mechanical advantage of my new deltas. It’s clear from that response curve that they use the steep bit of the curve to close up the gap between the rim and the pad and they use the shallow bit of the curve to apply the force to the rim. The beauty of this is : the pad to rim gap is taken up with minimal brake lever movement to get you to the larger mechanical advantage end of the curve - and then further brake lever movement when the pad contacts the rim delivers slowly increasing mechanical advantage- with increased lever pressure- progressive braking. BUT this best of both worlds is based on a well-maintained gap between pads and rim. If the gap is too wide, the pad-rim contact will occur at the ‘high mechanical advantage’ end of the curve and the brakes will be vicious and grabby. If the gap is set too narrow, the pad-rim contact will occur at the ‘low mechanical advantage’ end of the curve - the brakes will be weak and lack feel. And even if you get them set up at the correct point on the curve, as the pads wear, the rim-pad gap increases and so the point on the curve shifts to the right. Furthermore, using the brake barrel adjuster is pointless for adjusting the gap: what is important is the angle of the parallelogram at the point the pads contact the rims- and that is a function of rim width and pad wear. The adjuster will close the gap, but not change the position on the curve. As the pads wear, to keep the brakes at the same point on the response curve you either need to change to new pads (like the pro-teams did most nights) or use shim washers as spacers.
In summary, these brakes are darn clever. When set up right, they offer fast, progressive, powerful braking. When worn or maladjusted they can be grabby, feel-less and slow. I wonder how many critics have ridden bikes with these properly set up and maintained? The key is in adjustment and maintenance. If you like, they are the high maintenance racehorse of the vintage bike world… not for everyone but powerful and rewarding when you master them. Oh, and did I say they are beautiful too?
Das entspricht im Großen und Ganzen meinen eigenen Erfahrungen. Aus den o.g Gründen habe ich Unterlegscheiben nach Maß für die Verwendung breiterer Felgen (C17) in Verbindung mit den originalen Bremsschuhen der Delta Bremsen.
Re: A...B...C...Delta - Projekt...
Newsletter
