Kannst mal deine Heatmap online als Foto stellen?Ich habe jetzt 53619
Ich bin jetzt bei knapp 9000 und 35x35
124 x 124? Das reicht aber nicht lange😎Dort werden die 124x124 Kacheln um den aktuellen Homepoint beim Download als Garmin Map Overlay gespeichert.
Meinst Du https://statshunters.com/ ?Ja, bin ich, danke!
Dort ist ja aber auch kein Link zur App/Map..
Wo kann ich die denn downloaden?
Grüße
For those who love getting out into the wilderness where few others venture, the Explorer Score could be for you. The fewer the number of visitors to your tiles there are, the higher your score:
Total up those points for all of your visited tiles and you have your Explorer Score.
- 1 visitor (i.e. only you) to the tile: 5 points
- 2 visitors (including you): 4 points
- 3 visitors: 3 points
- 4 visitors: 2 points
- 5 or more visitors: 1 point
The Max Cluster Span rewards how far you have extended your Max Cluster North, South, East and West. It is calculated as follows (note, each tile has an X and X value between 0 and 16,347 to indicate its location on the world) using the max and min X/Y values for your Max Cluster tiles:
([Max X] – [Min X] + 1) + ([Max Y] – [Min Y] + 1) = Max Cluster Span
When you have the Max Cluster shown on the Activities page map then you will see the outline of the Max Cluster Span also shown.
Provided more for completeness as it was deemed to be not enough of a challenge when coming up with the concept of the Max Cluster. As long as a tile is alongside (top, bottom, left or right) another tile then those tiles are connected. A single long ride can connect multiple areas very easily whereas connecting Clusters is much more tricky.
Getting very niche now, but in the as always in VeloViewer, if there is a stat to be worked out, it’ll do it!
Two values are provided for both rows and columns of columns:
- Max connected – ticked, adjacent tiles in a single column/row. You may well have gaps in ticked tiles so this stat is the maximum number that are ticked without any gaps.
- Total ticked in a column/row.
Immerhin beim max Cluster Spam, Total Column und Total row bin ich vorne dabei, verstehen tue ich es noch nicht.
Danke für den Hinweis und das zusammenfassen. Schöne neue Statistik-Spielerei.Heute gab Veloviewer viele neue Statts bekannt, ich zitiere mal aus der Explorer Overviewer Seite, https://blog.veloviewer.com/veloviewer-explorer-overview/:
Explorer score:
Max Cluster Span
Max Connected
Columns/Rows
Leaderboards sind noch nicht ganz ergänzt, aber es gibt jetzt noch mehr zum mitspielen.
Bei connected row habe ich schon eine Idee für nächstes Jahr, eine Fahrt von Suwalki über Vilnius nach Tallinn wird die Connected tiles mal massig in west-ost verlängeren, dann wurden die von Brest (Frankreich) bis Moskau laufen.
Dann werden die Neuerungen für dich weniger interessant sein. Für Radreisenden z.B. schon, dann gibt's ein recht langes zusammengeschlossenes Stück. Und wenn mehrere Reisen sich kreuzen, dann schon ganz.Ich habe keine Ahnung, was mir die Zahlen sagen sollen. Mein Cluster ist fast genauso quadratisch wie mein MaxSquare, die Erkenntnisse sind also marginal.![]()
