Dura Ace 2011
Thomas
Rennrad-News.de
30 Januar 2004
Bad Kreuznach
Shimano stellt neue Dura Aces Laufräder und Pedale vor - hier die Details:
Shimano has updated the DURA- ACE wheel set line-up completely, offering the perfect high-end road racing wheels for all riding circumstances. Besides the available rim choices of 24 and 50mm height, Shimano is now also offering a 35mm carbon rim that offers an excellent combination of high rigidity, low weight and excellent aerodynamics. All new wheel sets feature the new DURA-ACE 7900 hubs with Shimano’s proven cup-and-cone technology as well as a new bearing adjustment system that enables easy manual adjustment without the use of a cone wrench.
These DURA-ACE wheel sets have been tested extensively in the previous year by many professional riders, including Oscar Freire and Robert Gesink (Rabobank), Samuel Sanchez (Euskaltel) and Juan Antonio Flecha (SKY). Also the new carbon composite DURA-ACE pedals were tested by our sponsored professional teams over the previous year.
An overview of the new DURA-ACE products:
PD-7900
• DURA-ACE carbon composite SPD-SL pedal
• Maintaining all SPD-SL features and benefits
• Weight: 248g per pair
• Availability in the market: September 2010
WH-7900-C24-CL
• DURA-ACE Clincher wheel set with carbon laminated ultra thin aluminum rims
• Rim height: 24mm
• 16 butted, bladed, stainless steel spokes in the front and 20 in the rear wheel
• Weight: 1395g per set
• Availability in the market: November 2010
WH-7900-C24-TL
• DURA-ACE Tubeless wheel set with carbon laminated ultra thin aluminum rims
• Rim height: 24mm
• Weight: 1464g per set
WH-7900-C35-CL
• DURA-ACE Clincher wheel set with carbon-aluminum rims
• Rim height: 35mm
• Weight: 1627g per set
• Availability in the market: October 2010
WH-7900-C35-TU
• DURA-ACE Tubular wheel set with full carbon rims
• Rim height: 35mm
• Weight: 1339g per set
WH-7900-C50-CL
• Rim height: 50mm
• Weight: 1662g per set
• Availability in the market: April 2011
WH-7900-C50-TU
• Rim height: 50mm
• Weight: 1396g per set
AW: Dura Ace 2011
An alle Insider:
Wird es 2011 auch neue Gruppenkomponenten geben?
Nach der Ultegra in 2010 wäre Eigentlich jetzt wieder DA dran.
AW: Dura Ace 2011
An alle Insider:
Die DA7900 ist ja erst gerade neu gekommen. Danach kam die Ultegra 6700 in ähnlichem Design. Zuerst kommt jeweils die DA, dann die Ultegra und dann die 105. Dieses Jahr ist die 105 dran. Bis die nächste DA kommt, dürfte es noch zwei, drei Jahre dauern, da eine Generation etwa vier, fünf Jahre auf dem Markt bleibt.
