Lbrtsn
- 23 Januar 2014
Diese Statistiken verzerren auf den ersten Blick allerdings auch etwas.LR hat knapp unter 7 W/kg für 39:50 Minuten gestern für Pogi berechnet.
Für Pantani wurden für L'Alpe d'Huez / 1997 ca. 7.2 W/kg für 37:35 Minuten berechnet.
Also ja, Pantani hat mehr getreten, aber ganz weit entfernt ist Pogi jetzt auch nicht. Und die Etappe war gestern sehr hart, sprich Pogacar hatte deutlich mehr Vorbelastung als Pantani bei seinem L'Alpe d'Huez Ritt.
Langversion von LR:
Pogačar set a new climbing record on Plateau de Beille, beating Marco Pantani’s 1998 effort by 3 minutes and 44 seconds. Pogačar did not have the perfect conditions as it was a headwind, but his performance was the greatest in cycling history. Pantani had a 6.96-kilogram aluminium bike but had higher CdA and rolling resistance than Pogačar, but on an 8% climb aerodynamics, whilst important, are not the most crucial thing. It is watts that are the most important like Pogačar said earlier this Tour, and the UAE superstar had perhaps the strongest legs any cyclist has ever had.
Pogačar did 6.98 ᵉW/Kg for 39:50 min, which is by far the greatest climbing performance ever, taking into account conditions and the stage difficulty. Sea normalised power for this historic effort is 7.27 ᵉW/Kg. Pogačar’s adjusted altitude score was 696, which means this performance was equivalent to pushing 6.96 ᵉW/Kg for 60 minutes at sea level. Jonas Vingegaard, despite losing 68 seconds did the second-greatest climbing performance of all time. The Dane did 6.85 ᵉW/Kg for 40:58 min. His altitude score was the second highest in history with 685. Until today, Marco Pantani’s Alpe d’Huez in 1997 was the best in history. Remco Evenepoel lost 2:51 min on a climb to Pogačar, but his performance still was the 23rd best of all-time as he pushed 6.53 ᵉW/Kg for 42:41, which for sea level normalised is 6.81 ᵉW/Kg. Evenepoel’s performance still is the third best in the 21st century. Pogačar’s Stage 14 effort on Pla d’Adet is the fourth best.
https://lanternerouge.com/2024/07/1...ateau-de-beille-tour-de-france-2024-stage-15/
Bei der puren Zeit könnte man denken, die sind da alle einzeln im iTT hochgefahren. Dabei sinds ja meist nur ein paar Km am Ende, die den einzelnen Unterschied ausmachen. Vorher wird der allergrößte Teil in der Gruppe hochgeheizt. Und da entsteht die Pace je nach Taktik.
Muss man hier natürlich keinem erklären, aber Außenstehende könnten denken, dass seien komplette Einzelleistungen.
