Hello everyone,
I'm sorry to write in English, but I do not speak German at all
But I really need your help about the sizing of this bike...
So I thank anyone who could help me.
I choose this bike to replace my Van Rysel EDR AF105 which I had in S size.
I'm 1m71/1m72 tall and my leg size is arround 81cm.
My saddle height recommended (72cm)
With the Van Rysel I put a 80mm stem instead of the default 90mm to be more confortable and it works, but I still had the feeling that something missed, when I grab the brake lever hood I had the impression that I lacked 1cm or 2 to be perfectly comfortable in this position.
Here you can find a comparaison between the two bike: https://bikeinsights.com/compare?geometries=5f22c8135f0c920017fc3667,617c3ef4b431bd001caab090
Cube calculator indicate 53cm for my size.
But It seems, 50cm will more fit to my size with my feedback on the Van Rysel.
About the seatpost with the 50cm size:
I would have to extend the seatpost by about 28cm, so there would be 7cm left in the seat tube but I don't count the height of the saddle (5cm between the bottom of the rail and the seat), so more like 12cm in fact, that's 1/3 of the seat post retracted into the seat tube, so looks fine to me ?
What do you think, 50cm or 53cm ?
Sadly, I cannot test those bike to a dealer shop
Thank you very much.
______
German Google traduction:
Es tut mir leid, dass ich auf Englisch schreibe, aber ich spreche überhaupt kein Deutsch
Aber ich brauche wirklich deine Hilfe bezüglich der Größe dieses Fahrrads ...
Deshalb danke ich jedem, der mir helfen konnte.
Ich habe dieses Fahrrad als Ersatz für mein Van Rysel EDR AF105 gewählt, das ich in der Größe S hatte.
Ich bin 1,71 m/1,72 m groß und habe eine Beingröße von ca. 81 cm.
Meine empfohlene Sattelhöhe (72 cm)
Beim Van Rysel habe ich einen 80-mm-Vorbau anstelle des standardmäßigen 90-mm-Vorbaus verwendet, um komfortabler zu sein, und es funktioniert, aber ich hatte immer noch das Gefühl, dass etwas fehlte. Als ich die Bremshebelhaube ergriff, hatte ich den Eindruck, dass mir 1 cm oder 2 bis 3 cm fehlten Fühlen Sie sich in dieser Position vollkommen wohl.
Hier finden Sie einen Vergleich zwischen den beiden Fahrrädern: https://bikeinsights.com/compare?geometries=5f22c8135f0c920017fc3667,617c3ef4b431bd001caab090
Der Würfelrechner gibt für meine Größe 53 cm an.
Aber es scheint, dass 50 cm aufgrund meines Feedbacks zum Van Rysel eher zu meiner Größe passen.
Über die Sattelstütze mit der 50cm-Größe:
Ich müsste die Sattelstütze um ca. 28 cm verlängern, sodass noch 7 cm im Sattelrohr verbleiben würden, aber die Höhe des Sattels zähle ich nicht mit (5 cm zwischen der Unterseite der Schiene und dem Sitz), also eher 12 cm Tatsächlich ist das 1/3 der Sattelstütze im Sitzrohr eingefahren, sieht also für mich gut aus?
Was meint Ihr, 50cm oder 53cm?
Leider kann ich diese Fahrräder nicht bei einem Händler testen
Vielen Dank.
______
Vielen Dank.
